liyinjack wrote:Thanks for the advice. I dont have the grinder. I though the illy grind coffee was very fine and should be good enough for espresso purpose because the price is not cheap. ($17 a can)
I want to know more about the fineness of the grind. Is it correct that the more fine of the grind the better espresso you have ?
Thanks!!!
More important than grind itself is what you're grinding. If you're not grinding - that's already a problem for preparing proper espresso. Pre-ground is stale ground coffee and the 'freshness' that is locked into those cans lasts about a second... not literally, but it's not worth the money for proper espresso extraction.
Fresh beans < 2 weeks old at the VERY least.
There's a thread of "my favourite roasters" that will have a large list of pro roasters that most everyone uses to get their fresh beans. However, before any of that I guess you'll have to decide to buy a grinder...
