edwa wrote:mrgnomer,
Interesting observation, I hope we get some feedback to the clarity, depth vs. blurred, muddy.
What is this from, is it the pull, is this better extraction? Does the crema last as long or longer than the Silvia crema did? Are you using the same beans?
Maybe this question should be posted in its own thread so it gets due attention?
Lastly, how would you describe the taste difference? Are you getting more flavor from the shot pulled on the Hx machine?
Thanks,
Ed
I think it might be due to the e61 preinfusion. There's a thread going on preinfusion vs. no preinfusion and one observation was that preinfusion might 'muddy' the taste of the shot vs. no preinfusion. With my Vetrano the preinfusion is about 5 sec and it seems that it's true, preinfusion expanding the puck makes it resist extraction pressure better which helps for a longer, maybe more even extraction, but I find that taste in the cup lacks the depth I got from very good Silvia shots.
Now a very good Silvia shot came about 1 in 6-10 for me with about 40% blonding early or channeling in some way. With the Vetrano a bad shot only comes when the grind is off from switching to a new roast or going from a really humid day to a dry day. When the grind is on and everything else like dose, distributing and tamp line up pretty good the shots are consistently better than the average Silvia shot. Still, when the Silvia shot was dead on I could taste a good separation between the sweet, creamy, nutty notes of the roast. I thought the Vetrano would get me those kind of shots consistently but for the most part those tasty notes are blurred.
I'm sure my Silvia's pump pressure was higher than 9 bar so that's why I think it might be the pump pressure affecting the taste in the cup. I haven't raised the Vetrano's pump pressure to see what affect it would have but maybe I should.
The Vetrano pulls are all crema from start to finish and settle out over about 30sec to a minute after pulling. I home roast so the beans are fresh. The shots are very tasty and I am more pleased with their consistent quality vs. the Silvia. Still, I'd like to pull shots where the notes are more distinct.
