another_jim wrote:I'm not ready to concede my main two points, which are:
-- The consistency of correlation of refractometer readings to solids concentration and extraction is not known....I'm more concerned with systematic errors due to different conversion constants for different coffees, grinders, baskets, etc.
-- The conversion that Terroir uses is unpublished. Until it is, it would be better to communicate with the most widely available units, e.g. brix for refractometers and CaCO3 concentration for conductivity meters.
Regarding your first point:
I think it's good that you're skeptical. At this point I'm a lot less skeptical than you, although I want to see more data before I'm completely won over.
The table I posted is hard to read (thanks to Dan's 700 px limit), but it contains trials using Gimme's Leftist blend (dark) and Intelly's Black Cat (medium), and includes doses of 13-17 grams. It would be good to torture test the method to try and get as wide a range of non-soluble percentages as possible.
Vince from Terroir is lining up some fairly ambitious testing sessions; I'm not sure exactly what he'll publish, but it will be interesting data, I'm sure.
I encourage you to do the math for yourself, but as stated in a previous post, I believe that the likely limits of non-soluble percentages will result in a calculated Total Brew Solids error of only plus or minus 0.5%.
Regarding your second point:
Forget about the conductivity meters. Although they won't tell you as much, the manufacturers of the meters decline to guarantee a reasonable accuracy for coffee because their own engineers know they stink in this application.
As far as the brix meters go, the analog handheld ones are cheap but take a lot of practice (and a lot of imagination!) before one can use them well. Since you already have one, for testing purposes you could multiply the brix reading by .95 or by 1.0 to get TBS and hope for the best!
Also, as you say, the coolest thing about this method is that it's so quick and easy. An easy method that's reasonably accurate is going to be a lot more useful than a super accurate but tedious method that stinks up your apartment.
