another_jim wrote:I want them all.
I'll try and measure up my La Peppina and Gaggia Factory baskets then.
another_jim wrote:How different is your lever from a regular machine in terms of grind requirements. Suppose you grind coffee for a good shot on your pump machine. Then you use the conversion based on hole area to load the equivalent dose/same grind into your lever basket. If the resulting shot is a gusher or a choke it tells you something about the lever group. The NS Athena (Astoria group) required an extra fine grind when using normal baskets, so the idea is not a stretch.
Since I'm running lever only as my regular machine, such a comparison is hard to make. My La Peppina and my Mypressi Twist are pretty close in grind, but the Gaggia Factory takes quite a bit finer grind. Oddly, when I was pulling side-by-side shots with Dr. Gary with his La Pavoni, the Gaggia Factory required a much finer grind then his La Pavoni which surprised me as the baskets should be the same.
