He was very pleased and comforted by it, and suggested that this could serve as the basic beginning instruction for anyone thinking about getting into espresso, and suffering some fears.
I offer this as the skeleton; not a be-all, end-all espresso instruction, but as a simple, basic training, intro to espresso, quick start users guide. I invite all criticisms, as this is a work in progress, and presently limited by my imperfect knowledge and writing/typing skills.
There are only a few tricks to getting good espresso instead of bad or mediocre, and the first are the four M's:
Miscela, Macinadosatore, Macchina, and Mano.
Blend, Grind, machine, and hand.
Blend; start with good ingredients. Fresh coffee, roasted less than fifteen days ago, but probably more than three or five days, depending on the bean, and ground right before (within minutes) of extraction.
This implies good water, too. Good coffee and good water go a long way to getting good espresso. No matter what else you do, if you have bad coffee or bad water, you will end up with bad espresso. These are the basics building blocks, the foundation if you will. Without them, there is no hope.
Grinder is the thing that makes the bean give up it's treasures. The ground particles should be as identical in size as possible, as that will encourage each particle to spend the same amount of time as any other in the water. More important than the machine, therefore listed first.
Machine. Really, the espresso machine only makes water hot and pushes it through the puck at pressure. The difference between a Silvia and the La Marzocco GS3 is that the GS3 is far easier to control that temp and the pressure, and to do it consistently. Other than that, given a similar grinder and the same beans, the shots that you would pull on either should be nearly indistinguishable. A machine that pushes too much or not enough pressure through the puck, or water that is too hot or not hot enough, is inadequate. Once it reaches nine Bar and 88 to 96 degrees C, it's adequate. Anything more just makes it more reliable, more repeatable, or easier.
Hand refers to barista skills. They are fairly simple, and the topic of much controversy, but the basics are easy. Find a dose of coffee that and a grind for that dose that consistently provides a one-and-a-half to two ounce espresso in twenty-five to thirty seconds before blonding*. To find the dose, one grinds a level basket full of grounds, tamps, and lock the portafilter in the group. The top of the puck should just show the impression of the dispersion screen screw, or, lacking that screw, the faintest impression of a dime between the top of the puck and the dispersion screen. To find the proper grind, pull that dose, adjusting for a finer grind if it runs two ounces in less than twenty-five seconds, and adjusting for a coarser grind if it doesn't run an ounce-and-a-half in thirty seconds.**
*Blonding refers to the end of a pull, where the result of more water passing through the puck doesn't result in more of the good solubles in the cup. The Head of the pull will be dark, drippy, and sometimes look almost like driveway oil, the beginning will rapidly develop an auburn, or redwood coloured mousetail, or pouring-honey-like appearance, and then soon will start to tiger-stripe and mottle, with dark drops of concentrated dissolved goodness running in the pour. Once all evidence of these stripes and spots disappears, all of the good tasting solubles have been exhausted from the puck, and you are only extracting bitterness, ashiness, and other bad tasting elements.
**All of these timings are a general decent shot. Some beans will taste better with a short pull of two ounces, some will blonde after one-and-a-half ounces, and there is the occasional bean that will benefit, and stay dark, for a good long ristretto pull. Experiment within these parameters until you are comfortable and bored enough to explore.
Don't fear the big machines.The only difference between the inexpensive counter-tops and the industrial.commercial giants is that they are easier, more reliable, and more repeatable.
