Alberto, you've probably seen by now that the big grinders you often see were originally designed for commercial use, and the huge hoppers are appropriate in that environment where a several pounds of coffee vanish quickly into a long line of lattes, and where multiple grinders handle the various options for decaf, coarser pour-over grinding and so forth.
But these big grinders, often with big conical burrs and slower motors, not only handle higher volumes, but in general provide better and more consistent grinding than the smaller units. So, there's an entire cult of home baristas who try to gain these advantages by taming big commercial units for home use, some via straightforward hopper-ectomies, others by adding or subtracting other components (e.g. the Schectermatic Schnozzola) or progressively intricate or complex modifications.
And some "Titan" grinders are more adaptable than others, as evidenced by the replies from Mitch, Derek Chris above and others. You will find many other threads here on the subject (check the "Grinder" area). I recently went through one such project based on a Macap M7K for example, and posted some
text and pictures about the process which can give you an idea of at least some of possibilities that exist.
