Hi guys,
I'm afraid there's something wrong with at least one piece of the espresso equation at my house and I simply can't believe it's so damn hard to get a proper shot with this kind of setup. The usual suspect is the grinder, so I got my Macap MC4 out and tried it to see how the extractions look/taste compared to the Major:
- here's a shot from my Macap
http://www.flickr.com/photos/tompjagiello/3847723847/- and here's a shot from my Major
http://www.flickr.com/photos/tompjagiello/3847737881/Taste wise the Macap was a bit more spicy and the Major was a bit sweeter. Both shots not too bad, but nothing to write home about. Bitterness on a reasonable level, medium body, good sweet/acidic/sour balance. Of course the extraction from Major was off due to uneven distribution.
Because the shot from the Major was a bit too fast I switched to a slightly finer grinder setting and screwed up my distribution again as I got this:
http://www.flickr.com/photos/tompjagiello/3847751033/Too bitter, but still not awful considering the look. Then again I had like 6-7 double espressos now, so I might be talking rubbish.
I'm using a fresh blend, 5 days old Perfetio blend from my local roaster and I'm sure there's nothing wrong with the bean. The pressure on the pump is 8.5bar, I'm using the smaller Kehin gicleur, no needle valve, no preinfusion. Dose is 14.5g in the original ridged basket, temperature around 91*C, tried lower but it was too acidic.
As I wrote before, my first suspect was the grinder, but I get similar channeling with the Macap as well, so I think it's not it. It's true that the shots from the Macap look a bit more even, but taste wise it is similar. I will try to test the grinder with a different machine and see what this test shows. One thing that's a bit odd with the Major is that the shot can start fast but slows down a few seconds earlier. For example it beads evenly, rather fast but then stops and the whole thing drips for quite a long while before forming a single stream. With the Macap the transition between beading and stream is faster and there's no slow down.
Another suspect would be my pump inline pressure which I agree is probably too low, only 1bar. Other things I can think of would be water distribution at the group (I'm planning to switch to an LM type of distribution simply to check how that works) and/or water line going from the pump to the machine which is only 10mm OD. I know Dave uses 1/2" and I think he mentioned he had problems with lower diameter and/or low pressure on the supply line in his review thread.
Of course I might be missing the obvious cause of my problems - me, although I try to do as little as possible when preparing the shot. I dose straight from the funnel into the basket, do a light tamp, a slight twist with no pressure to clean the base of the tamper from coffee grounds and lock. Perhaps my distribution is off?
Regards,
dsc.
