by JmanEspresso on Mon Aug 24, 2009 2:29 am
Ive always been curious about the Elektras shots. When you guys are using your double basket, so say, 14grs, and the shot is yielding you 1.5oz.. The Videos Ive seen dont show the shot running TOO tight.. But the mouthfeel/texture of the shot is what Im curious about. At only 14grs are the shots thick and syrupy?
See, personally, I dont ever pull "Normale" shots. Main reason being, is Im after the much thicker texture of a ristretto. But, Lets say Im using a low dose, 14, even 15grs.. Ive got to pull the shot pretty darn tight to get the texture Im after. I wonder the same about the Vivaldi.. ASt those "low" doses, do you still get that heavy thickness running 1.5oz in under 30 seconds? Obviously you dont need to Answer about the LS.
For what its worth, my normal dose is between 18-20, and normal shot time is 30-35 seconds. Gives me the taste, texture and Volume I desire.
