drdna wrote:...I am suggesting that fixed preinfusion reduces the risk of channeling but may increase the average intrashot temperature variation...
With a pressurized boiler whose water is greatly above desired brew temp, and so requiring a massive brass bell heat sink to mitigate the excessive temperature: if the puck is first warmed by the preinfusion, then the peak temperature at the puck/in the puck/throughout the puck could be significantly higher than it would have been without a preinfusion.
With an unpressurized boiler ("kettle") whose water is just a few degrees above desired brew temp, and so not requiring a massive heat sink (stainless steel collar suffices), the higher peak temperature after preinfusion will be far less alpine.
The unpressurized kettle would permit designs that allow for user-defined preinfusion times.
Time being an important factor in solubility, I'd opt for a machine that allows as long a preinfusion as I might want, without the risk of, say, the HX heating up too much as I lingered during this phase, or the puck getting too warm. The hotter the machine, the more precipitous the slope of misfortune.
Conclusions drawn from a study of one class of machine (boiler) may not apply to other classes of machine (kettle).
