popeye wrote:I have stumbled upon a technique for easily removing my grouphead gasket/shower screen on my E61 Isomac Zaffiro and i was wondering if anyone else uses it or if it is somehow damaging.
popeye wrote:I have stumbled upon a technique for easily removing my grouphead gasket/shower screen on my E61 Isomac Zaffiro and i was wondering if anyone else uses it or if it is somehow damaging. I place a backflush disk in my portafilter and do the portafilter wiggle under pressure. As i do the wiggle, i create a temporary seal so the pressure (on my gauge) builds up to maybe 3-5 bars. Then i quickly apply maybe 5-10 pounds of pressure counterclockwise to break the seal and allow water to flow again. Doing this rapidly 4-5 times seems to work the gasket off (so much that it may actually drop or pop off on the last time.) The trick is allowing the portafilter to catch, but not allowing the pump to build up so much pressure that the "pop" of breaking the seal is damaging to the machine. It allows me to get the gasket and shower screen off without damaging the gasket for easy cleaning. Any comments?
Marshall wrote:Yes. This falls under the ever-popular home barista category of solutions to problems that don't exist. If you are backflushing properly, there shouldn't be anything behind the screen to worry about. The only time the gasket needs to be removed is when you replace it, at which time damaging it is irrelevant.
rpirong wrote:Yes, but it still can be a difficult manuever, so any tips on removing it when it needs to be replaced sure are appreciated!
Marshall wrote:The worst, baked-in, dried out old gaskets can be removed by screwing in a self-tapping screw a few turns and grasping the screwhead with a pliers. I think I picked that trick up from Randy Glass. Fortunately, I only had to use it once. A skinny screwdriver head has worked well as a wedge with "fresher" gaskets.
