I have found several existing threads on the subject but I thought it was better to open a new one since it is referring to a different coffee machine, a professional Fiorenzato Ducale, bought second hand.
I have been learning a lot of tecniques and theories about coffee and cappuccino and I have been trying to squeeze the most from my espresso machine.
I have another thread open here if you want to have a look.
I have been trying different grinder settings, different weights, different temperatures and pressure: the common issue is blonding. I have blonding after 12/15 seconds all the time. I also tried to overdose, still blonding.
I can see what I think are "tunnels" after the shot on the coffee puck but I didn't manage to get rid of them despite all my efforts.
The coffee is grinded fresh all the time, the dose is between 7 and 8gr (tried different doses), and I understand that tamping is very important. I think I am doing it correctly, trying to be as even a possible and tamping with 12 chilos.
I preflush the machine until it stops boiling, and the water pressure reads 8.5atm.
Everything else "works" as the "manual" says: I can have an over/underextracted coffee depending on dose, grind, time... but ALL the time after 15s I have the bloody "white button" on the cream, even though the cream looks like tiger fur.
I do not have tunnelling with 9gr of powder (that should be actually 10gr according to my scale, but a more exact one is on its way) and with 9grx2 I then overfill the double filter.
Here are some pictures
coffee puck after extraction with 9gr on the grinder (it should be actually 10gr)
Quantity of powder used
Tamped powder
Result, 15s.
According to the manual, I should make the powder coarser, but anyway I would have blonding after 15s anyway.
Here is with 7-8gr of powder
Anything I am missing?
Ok, next time I'll use my reflex
Thanks everybody!
Tony
