DigMe wrote:And did it taste bad? Do you just WDT and tamp or is there anything else in the mix to level the grounds? Have you tried the finer grind with a lighter tamp?
brad
Yes, it was a 15 second, 1 oz total shot volume (again 17g double basket naked pf) that tasted mildly underextracted. I know I can try pulling a little hotter to help with that. I wouldn't be worrying if it was just off by a couple of seconds, but 15 s is fast! It comes out a little too light in body, and the entire pour is like a gush rather than the honey-drool that we espressopornographers seek.
I dose into a metal jug, WDT just for a couple of seconds to break clumps, pour into PF, tap tap tap to settle the bottom portion, another WDT to fluff out the top and level it, and then tamp. I tamp lightly - fingertip tamp just to bring the tamper top level with the top of the basket and seal the grinds together. I probably use 5-10 lbs of force. I guess next time I can try a harder tamp, but I don't think it's gonna add more than 3-4 seconds to the pour.
My target is a 1.75 oz double which means I have to back off the grind another two notches. It's gonna take the pour time down to 10-12 seconds. I don't get it...
I have pressure tested this machine with a rigged PF and it's dead on at 9 bar avg.
~bean
