I am drinking espresso straight if it taste good ,or else I will just steam some milk and make a latte. I think I make a lungo instead since it taste like diluted espresso. I haven't try stopping the shot by color and measure weight of the shot, so I will try that later.
Randy G. wrote:How long do you let the machine warm up before use?
Are you SURE that the coffee is fresh? How fresh? What coffee is it?
I warm it up at least one hour before use. The coffee is fresh. One day fresh. It is a Brazil Cerrado. BTW, the micro-roastery is called "fresh"
Randy G. wrote:Tap the BOTTOM of the portafilter around the edges of the bottom, LIGHTLY, moving all around the portafilter. The goal is to EVENLY settle the coffee so that it is level and evenly distributed. No WDT.
Tamp level and hard. Forget 15 pounds. Tamp to 50, or 60. Just press hard, but level. Forget polishing.
Just curious, isn't tapping bad? And what does polishing do, I just do it for aesthetics.
Now, COFFEE time! I will be right back. Thanks guys!
