I went through the same struggle a year ago when I got my Vetrano and installed the thermometer adapter - now I don't give it second thought. Some points I've found to be key from the above posts:
- first thing in the morning the machine goes on about 30-40 minutes before use.
- pour milk in pitcher, dose beans into grinder, and get ready generally.
- draw water through brewhead until thermometer displays the chosen temperature. This is my pre-cool.
- grind, dose, tamp
- draw water again to once again cool to predetermined temperature.
- lock and pull.
- subsequent shots done in succession need no further cooling.
Its all about having a routine - I use exactly the same method but without the second flush.
Best advice is to flush to a given temperature for all your pulls for a few days, see how that tastes to you, then try a degree or two different temperature and see if that changes things. Don't worry about the "True" extraction temperature. Use the thermometer as the starting line, the brew-button to start the race, and your palate is the best way to judge who wins.
Exactly!! This is where your routine meets your espresso preference - you have to learn what temperature to start at by trial and taste. Each coffee bean and sometimes even batch is different and requires a different starting point (measured by your thermometer adapter). I use Black Cat and flush to 195 and then prepare the shot - in the 25-30 seconds it takes to do this (I know the timing because I timed and modified my preparation routine until I was consistent at 25-30 seconds) my machine rebounds to 198 which is my starting point. This makes an espresso just right for my taste.
Don't get too caught up in all the temperature curve stuff. You can get eactly the same results if you use a stop watch and time your flushes and rebounds instead of following the temperature. The thermometer adapter just makes it easier to hit the same points repeatably (its a PITA to follow a stop watch while going through your routine).
Best of luck.
Dave
PS - my Vetrano idles at about 210 - I have mine hard plumbed so incoming water is cooler and it still rebounds pretty quick. 215 seems awful high - I think you could get away with lowering your p-stat a little to cut down on flush water consumption.
