another_jim wrote:When you backflush, once the basket has filled with an ounce or so of water (which is what gets backflushed out), there is no flow at all in the thermosyphon or HX -- there's nowhere for the water to go. The only flow is through the OPV, upstream of the HX.
ok i understand that. makes sense.
The cooling you observe is simply the group cooling off. In a thermosyphon, the group heating depends on the thermosyphon circulation, this is cut off during the backflush, so the group is no longer heated. Presumably, in a machine where the group is bolted to the HX and boiler, like the Cimbali, Bezzera, the home Elektra HX, etc etc, backflushing does not affect the groups temperature.
this makes sense also. i assume the thermosyphon is cut off by the pressure. and the thermosyphon runs still while you have the pump running but not under pressure. and a smaller restrictor in my thermosyphon would keep the group cooler, then less flushing is required because the group is cooler?
i realize that im really cooling the group. maybe this could still be useful after a long idle period? or maybe a couple of backflushes then a cooling flush to even tthe group temp back out. but still u se less water.
could this be useful for those who are putting volvic into the machine and just flushing out 6-7oz a time with the normal "water dance"?
thanks for your help.
jon
