Hi guys,
recently I've noticed a strange thing happening during pretty much all extractions on my Elektra. This is mostly the effect of comparison between what I see on my machine and various vids of naked extractions and might be the cause of most of my problems with espresso. Just to clarify, this is not only a visual problem, to be honest if the coffee tastes good I wouldn't worry about how it looks like, but sadly it's the opposite, coffee tastes quite bad and has been like this for quite a while. Now I'm not sure this is actually an issue, it might be the coffee I'm using or the way I'm packing it in the basket, so it would be nice if you could check on your own rigs and reply if it's the same or not.
Before I go into the details I wanted to note that yes I'm using fresh coffee, I've tried various ages, super fresh to two weeks old, various doses, various tamp forces, various tamp/distribution techniques, various pressures, various temperatures, various grind settings. First I thought it might be the pump, which was a FOT model with a very high water debit, but after switching to the TMFR, which has a much lower debit, the problem is still there. I've tried various fixes and mods on the machine itself and nothing seems to work, so I'm starting to suspect the grinder which I've been using for quite a while now. As it's a Mazzer Major I doubt it's the burrs as those can take 10 times the amount of beans I grind on it, but on the other hand it's been a while since I've changed them, definitely more than a year ago. Still my average weekly consumption is somewhere around 300g, which gives 1.0-1.2kg per month, so assuming I had the burrs for 1.5year it gives around 20kg, probably nothing compared to what the burrs can take. I never had a problem with rocks or other hard matter in the burr chamber, so the burrs should be damage free.
As I already mentioned in the
profiling topic the main problem I'm getting is drippy extractions. Instead of getting a nice cone/stream after a few seconds from the moment the beading starts, the coffee simply drips for a long time and after the stream finally forms it takes only a few seconds for it to go blond. If I grind coarser the stream of course forms properly, but the whole thing blonds even faster and the shot is too fast, with the fine grind the time might be right but the volume is way below normal values, usually less than 20-30ml from a double. Dunno why this happens but it happens with pretty much every coffee I've used and I'm curious if it's cause by too much fines? It's a known fact that too little fines will not work for espresso, but what about too much fines? if that's the case would old worn out burrs cause this? another suspect on the list is preinfusion which normally doesn't happen on the Elektra. I will try to test this today, swapping the smaller Keihin jet with the original from the Elektra.
As usual any and all feedback is welcome.
Regards,
dsc.
