by dsc on Sat Dec 05, 2009 9:52 pm
Hi guys,
a quick update:
I've tested my grinder on James's (SQM) two group Synesso and it performed very well, pours were very nice, tasted incredible (winter espresso) and we had no problems I normally see at home. This means it's definitely not the grinder as it was working as well as the usual SQM Synesso partner, the Anfim (I believe it's a Super Caimano). The machine was running at 0s delay-relay preinfusion, so only flow restricted preinfusion (3-4s rampup to full pressure) and with the pump set to 115PSI (roughly 8bar, measured with a Scace). So with the grinder crossed out from the list of suspects I've tested myself and pulled a shot using my usual routine, grind straight to the basket, light thump on the fork, no distribution and a tamp (harder than usual). Pour was good, no sprites, no channeling, tasted good. Another thing to cross off which leaves me with only one thing on the list: the machine.
Being a great guy that he is James gave me a bag of beans we used during testing, so I can check it out on my machine and we agreed I should probably try the grinder setting and dose (19g) on my Elektra, simply to see what happens. Now I haven't done that yet, but I also borrowed a Scace which I used already and I'm seeing around 120PSI on the group which corresponds to what my PT is telling me (8.3bar). I've checked this against my home made 'Scace' and it also shows the same, producing 60ml in 30s (same as the original Scace) under 8.3bar of pressure.
I'm very curious what tomorrow will bring, but without touching the grinder I should see a pretty decent extraction, or at least not a complete gusher.
Glad to know a bit more and that it's not the grinder, but to be honest it means the problem is even more complicated and harder to solve. At least now I know where to look. A huge thanks James for having me over and letting me play!!
Regards,
dsc.
