Double shots on triple basket
Postby matt1203 on Fri Aug 26, 2011 8:56 pm
I believe my bottomless portafilter is 21gram capacity, if I do double dose like 16 to 19 gram is it okay?
do I need to get double dose basket?
matt1203
Postby Javacat on Fri Aug 26, 2011 10:14 pm
Personally I don't think that I would ever dose under 19g in a triple basket. A good rule of thumb is to look for a screw impression on the puck when you remove the portafilter. If you don't see it, then you probably need to dose higher. There are definitely exception to this rule, for instance if you have a group that dosesn't have a screw or has a screw that is recessed.
Javacat
Postby another_jim on Fri Aug 26, 2011 10:38 pm
There is a range of acceptable espresso grind settings on your grinder. If you get finer than that, the shots will taste flat and have an overpowering caramel flavor; if you grind coarser than the range, the shot will be rough tasting, and both sour and cutting.
In general, baskets are designed to dose with about 2/5 to 1/2 inch clearance after you tamp, and should never show a screw mark. It is Italian orthodoxy, reproduced in the Illy espresso book, that a shot is ruined whenever the puck expands into the shower screen.
US espresso frequently breaks this with this orthodoxy and relies on overdosed, coarse ground shots. However, in general, the better the coffee, the worse it will taste coarsely ground in an overloaded basket. The popularity of the Strada and VST 18 grma baskets for 3rd wave espresso is that it can use a grind fine enough for high grown coffees, light roasted coffees at the higher dose US cafes prefer.
another_jim
Postby mitch236 on Sat Aug 27, 2011 10:31 am
While the screw test is fine, be careful not to look for it after you brew the shot because the puck can expand and hit the screen when the pump is turned off. Check for clearance with the dry tamped coffee bed prior to brewing. I frequently find the screw mark in my wet pucks.
mitch236
Postby Javacat on Sat Aug 27, 2011 11:33 am
I was referring to after the shot is pulled. The grounds should never contact the screen prior to pulling the shot - inconsistant extractions can result. There should definitely be headroom between the coffee and screen.
Javacat
Return to Tips and Techniques
