miam-miam wrote:When I dose so that the top of the puck hardly touches the shower screen screw before brewing, the puck is too shallow because my 58.0mm tamper gets stuck by the rounded bottom of the basket (I'm using a stock double basket). In this case, the basket holds 12g/12.5g of coffee and I have no idea how hard I really tamp.
This is where you go wrong. Compared to other machines, shower screen screw of all rancilio machines much more protruding. take a look at these -->
rancilio silvia shower screen,
marzocco linea,
smooth e-61 shower screen,
nuova simonelli oscar shower screen (edit: dan warned me about ns oscar's shower screen, it's a pod one but that's the only picture I could find for oscar --showing screw-- anyway keep in mind it's for you to see the screw part not the whole group head
edit2: thanks to dan, changed ns oscar link)
So you're definetely downdosing. Grind one or two steps coarser and use more coffee, don't worry about the screen screw. btw check your double basket's code (it's carved on your basket) the code for 14gr double basket
40.100.010, and 7gr single basket
40.100.001 All rancilio machines (silvia, epoca, classe 6, 8, 10) use exact same baskets.
try dosing and tamping like this
For your tamping, if you have a bathroom scale grab your tamper and push until you see 30lb/15kg do this several times so that you get used to it. That will teach you how to control your tamping pressure and from there you can tamp less or more.
edit: forgot to add this --> as far as I know there's not an official 12gr rancilio basket. Those 2 above with codes are the only ones (and there's another triple basket coded
40.100.096 but it's not in rancilio spare parts catalogue yet. besides you'll need triple portafilter with triple basket)
Resistance is futile. You will be caffeinated!
