I have a weird problem with my Isomac Zaffiro.
When pulling the lever to start the brewing the pressure is at 0 (I pull some water through the wand, if it is not, to equalize).
The pump starts working and when pressure is around 4 bar coffee starts pouring. The weird thing is that pressure keeps rising and stabilizes at 11 bar.
If this indicates some kind of channeling is it normal for the pressure to keep rising?
The coffee coming out at 4 bar is pretty much watery and foam starts to form as the pressure rises.
Putting in the cup after a few drops are out (losing the first few ml) makes a huge difference in the final taste. Channeling shouldn't have that effect according to my limited knowledge.
Another possible cause is that the basket (provided by Isomac as "double") is quite large. I believe the clearance between the puck and the screen might be more than enough.
Any help is deeply appreciated.
