cannonfodder wrote:Lately I have been experimenting with down dosing, grinding finer and tamping less.
This is the route I've been taking as well.
I even gave up on the fancy distribution and tamping techniques. I just dose into the portafilter, knock the top of the mound down with a NSEW finger swipe (real fast swipe) and then lightly tamp.
I continue with the WDT and NSEW for marginally better results. The biggest advantage is probably using the yogurt cup to direct grounds into the pf, and it also stabilizes the pf between the Mazzer dozerless chute and the pf forks so I don't have extra steps and mess. I pre-weigh unground beans per shot.
A light tamp for me is 20-30lbs.
My tamp is probably closer to 10. I've shifted my priorities re consistency: First, is dose. Because it is confirmed by a scale, might as well take advantage of that as a non-variable. I find that the lighter tamp combined with the measured dose is easier to keep level than a heavy tamp. The goal, of course, is to make fewest possible changes in the workflow and accomplish most modifications with the grind.
My shots are just as good and some blends behave even better.
My shots are better, though I'm also on a new-machine learning curve getting used to many different dynamics (LaSpaz).
Martin
