Do you adjust grind from double to single espressos?
Postby CoffeeOwl on Mon Nov 26, 2007 8:22 pm
Do you adjust grind from double shots to single shots? If yes, how?
(I think it could do as a poll, hopefully you do make singles... :))
'a a ha sha sa ma!
LMWDP #199
CoffeeOwl
Postby Kaffee Bitte on Mon Nov 26, 2007 8:42 pm
I most certainly do. I adjust the grind to a finer setting for singles. I also adjust my tamp pressure. Singles blond quickly with a double grind setting and a normal tamp. Try one or two notches lower, maybe more even. Then tamp with just the weight of the tamper. This has worked wonders for me on commercial machines and should work well on many home models. Remember to be very careful about the dose, since small single baskets will be much more likely to hit the shower screen.
Lynn G.
LMWDP # 110
____________________
Kaffee Bitte
Postby John P on Mon Nov 26, 2007 9:30 pm
We actually adjust our grind coarser for the singles. About 2 notches on a Super Jolly.
OR adjust your tamp a little lighter and watch the dosing... don't mound.
John Piquet
Salt Lake City, UT
caffedbolla.com
John P
Postby Mark08859 on Mon Nov 26, 2007 11:01 pm
I have to adjust coarser for singles. So, I pretty much don't bother with them. :lol:
Mark08859
Postby cannonfodder on Mon Nov 26, 2007 11:20 pm
Odd, I tighten up the grind but keep the tamp the same. less coffee=less resistance=finer grind to maintain the same extraction time.
cannonfodder
Postby malachi on Tue Nov 27, 2007 12:45 am
I use the same grind and just put the demi under one of the two spouts rather than both.
malachi
Postby cafeIKE on Tue Nov 27, 2007 1:19 am
cannonfodder wrote:Odd, I tighten up the grind but keep the tamp the same. less coffee=less resistance=finer grind to maintain the same extraction time.
Ditto
cafeIKE
Postby cannonfodder on Tue Nov 27, 2007 10:09 am
malachi wrote:I use the same grind and just put the demi under one of the two spouts rather than both.
That is what most café's do when you order a single, at least from my observation of café's in this country. They just dump half of the shot so they do not have to change grind/baskets. Personally, I think there is a taste difference between the single and double (when pulled using their respective baskets). So when I want a single it is for that change. However, I have not split a shot in years to compare a true single against a split double, sounds like an evening test.
cannonfodder
Postby Kaffee Bitte on Tue Nov 27, 2007 12:45 pm
cannonfodder wrote:Personally, I think there is a taste difference between the single and double (when pulled using their respective baskets). So when I want a single it is for that change. However, I have not split a shot in years to compare a true single against a split double, sounds like an evening test.
This is a worthy and enjoyable, if somewhat highly caffeinated evening test. I often equate singles flavor profile to something more similar to what spring levers will produce. When pulled correctly they will have more clarity and make for very tasty single origin shots, where often a double on a pump machine will just muck it up.
Lynn G.
LMWDP # 110
Kaffee Bitte
Postby CoffeeOwl on Tue Nov 27, 2007 1:57 pm
Kaffee Bitte wrote:When pulled correctly they will have more clarity and make for very tasty single origin shots, where often a double on a pump machine will just muck it up.
I found that out too (a brighter vs a kind of loaded taste*).
I also adjust the grind to a finer setting for singles, keeping tamp the same (actually trying :D to keep it the same, espro tamper is on order :roll: )
I put 9 grams into the single basket (fits easily) vs. 14 grams into the double.
Adjustment to a coarser grind for singles is a surprise
(but I've already heard about it)
EDIT: *of a double shot, I haven't yet had a single made by splitting a double at home
'a a ha sha sa ma!
LMWDP #199
CoffeeOwl
Next
Return to Tips and Techniques
