Evening Barry. Why does that story not surprise me... Hopefully Maddie and June are doing well. I was bummed when I saw your shop closing.
Back in the days before Scace I use to use the same TC up through the basket but the readings will swing too much to be very useful when the basket is full of coffee for the reasons Barry stated. If you want a more accurate water measurement, use a blank basket, drill a small hole in it and mount the TC in it but make sure the TC does not touch the shower screen. You can use a micro drill bit set to drill a small hole to allow water to flow. A single basket also works good, just stick a piece of duct tape over the holes on the inside then mount the TC just below the shower screen level. Then poke one hole open with a sowing needle. That will get you close to the proper water flow of a shot.
