I agree with Allon that single dosing with a Robur is problematic unless you rig a mini doser (e.g., like the one
here or
here). Without such a modification, the grind setting meanders towards more coarse as the weight of beans pushing towards the burrs diminishes.
Also, depending on the year of manufacture, the Linea may come with no gicleur or a 1.0mm one. Years ago when Counter Culture Coffee had Lineas in their espresso lab and changed them to 0.6mm gicleurs, I noticed a significant improvement in the "forgiveness factor" thanks to the slower pressure ramp up. It was certainly
possible to pull good shots on it either way, but the margin of error was higher after the change.
