cafeIKE wrote:It's important to have a tamper that allows you to judge level and head space EASILY while tamping.
+1
With my tamper (RB) I have my thumb, index and middle fingers on the outer rim of the tamper top edge- sort of in equilateral triangle position- with the tamper handle mid-palm. When I feel my fingers touch the edge of the basket rim, I stop my gentle downward pressure. Dust off the rim and apply tamp #2 (I'm a no tap, no polish guy). At this point the tamper top edge is a few mm below the basket rim. This seems to leave the perfect headspace for my particular A3. Also allows a quick feedback if my tamp is canted at all by noticing unequal basket contact pressure on my fingertips. I have also found that if any resistance at all is felt when locking the PF into the grouphead that I likely have OD'd the basket. Under the latter scenario, I'm a little more prone to experience the dreaded "espresso grenade" phenomenon...
IMO, one of the beautiful things about the A3 (OK, OK other machines too...) is that it allows one to use all of their senses in preparing the shot. See the beautiful gleaming chrome; touch the basket edge when tamping; listen to the sound of the sizzling cooling flush as it allows you to consistently and easily dial in to any desired temperature; feel the easily locked in PF; watch the perfectly tiger striped cone of espresso pour forth from the bottomless PF into the eagerly waiting Illy cup; swirl, smell, sip and taste one "10 shot" after another...
Wow, Pavlovian response initiated- better go lock my PF into the grouphead to warm up...
