I had to tilt my monitor to see your basket's screen clearly, but that did work.
Dan's right about everything, but niggler that I am I'll add two slight caveats.
(1) Perspective.
(a) Perhaps not perfect, but all in all it wasn't a bad shot.
(b) How did it taste? Diagnosis via naked pf comes after diagnosis via cup.
(2) Don't ignore the obvious. When the stream suddenly lightens by two shades, that's [ahem] meaningful. The biggest
visible flaw was letting the shot run too long. If your cups come with handles or shapes which allow them to be moved, and/or your machine has some sort of lever or switch allowing you to end the pour, you should make use of at least one of them sooner.
BDL
