Because of the configuration of my kitchen, I can't plumb the machine in. I use instead a pump to automatically pump up water from a 2 gal container located under the counter cabinet to feed the machine located above. This part works well.
Eventually it will comes to descale the dual boiler. My first thought is to make a descaling solution in the 2 gal container and pump it to both boilers. Draining the brew boiler seems obvious either through the hot water wand or the brew head but for the steam boiler, how can it be done ? Can anyone has some thought about it.
