by jlhsupport on Wed Oct 06, 2010 1:16 am
If you are choosing the Brewtus III-V that has a tank, you would likely have to remove the wire harness for the water level probe to get the steam boiler to fill to the top when descaling. Choosing a plumb-in model actually makes the process less involved as long as you have easy access to the top of the boiler and the drain plug on the bottom. I can perform the task much faster on machines that fit that scenario, since I don't have to use the pump. You wouldn't need to remove the wire for the water level probe because you'd be removing the whole probe (or vacuum breaker) to pour in your descale solution. As an added bonus, you can descale your vacuum breaker in the process.
While I agree that I wish more of these machines corrected for all of the little annoyances, such as descaling a HX (rarely an enjoyable task) or DB, from a manufacturing standpoint, there are problems with tying up all those loose ends. First of all, it's important to consider that adding a water tank to machines of this caliber is, for the most part, an afterthought. It is a workaround for the budding home enthusiast market as well as mobile coffee cart or catering services (though many still use plumbed-in equipment). The primary focus of commercial espresso machine manufacturers has traditionally been the food service establishment, and the preventative maintenance (PM) schedule on a machine at many restaurants is typically non-existent.
Also, since commercial espresso manufacturers mandate proper installation guidelines (regardless of whether they are followed) including water quality, it's not high on their design teams' priority lists to ensure that frequent descaling is made more user-friendly. Some companies have made it easy on techs and have for years, though usually on 4 liter and larger HX boilers (compact ones at or less than 2 liters tend to be annoying). Others have made attempts that seem like a good idea, such as having a drain cock at the end of a conveniently located narrow pipe, but ultimately turn out to be a huge hassle if proper water quality is not used. (Imagine 8 inches of quarter-inch copper pipe filled with scale.)
In the end, if a convenient maintenance feature is not already incorporated into the design, it's not likely to be added any time soon. Companies focus on features that they can market to the end user (think commercial here) rather than the tech. An establishment that actually has a service contract that covers PMs could care less how annoying it is for the tech to do the work. As you may have noticed, however, with the growing home enthusiast market in the US, issues specific to machines that have large prosumer followings are being addressed. The squeaky wheel still gets the grease, but it takes a pretty loud squeak for it to be heard all the way across the Atlantic.
Joshua Stack
JL Hufford
