The coarse grind with Rocky seems to be a common problem.
Got my Rocky 2nd hand and the previous owner never had problems with it...
I cant choke my Silvia while my cheaper Rancilio Jacky (nifty little grinder that) does that with no problems. Feels a bit weird using the Jacky and not touching rocky at all. Just ordered a new burr set for the rocky and im hoping it will do the trick. Will apply the teflon mod as well to get it all right in one try.
When disassembling the top burr of the Rocky i got to twist the burr with the hopper still mounted with the three screws on because if i removed the hopper the top burr is too tight to be turned. I really gotta apply some strength to get the top burr off.
Maybe im having the same issues as Scotto since i disassembled my rocky for cleaning purposes before i first used it:
gtrman wrote:Scotto,
turns out i had misaligned the hopper with the burr carrier and was 1/3 of a turn off, but seeing as there is a screw in the bottom of the hopper, i could not get past zero. upon taking the screw out and realigning the hopper, my life became much easier.
Which screw in the bottom of the hopper is the issue here? I can only think about the 3 screws to attach the hopper to the top burr of the rocky. Or do you mean the big screw, number 34 on this scheme :
http://www.mrcappuccino.com/servi...ckysch/rc4501s.pdf
Anyway, hope the new burrs will solve the problem here. Will report back when done.
