by drdna on Sat Feb 28, 2009 5:04 pm
I recently ran into a problem that I am sure we all have from one time to another. I was roasting a pound of espresso beans and was washing the dishes at the same time. Well, the beans reached second crack and I didn't get over to the roaster before they had got to a FC++, a little too far for this particular blend.
I ground a few samples and gave it a try, but found there was a marked ashy/ashen taste at the usual dose and temperature for this blend. Okay, I had burnt the beans; however, I didn't want to throw out a pound of freshly roasted coffee. Now what?
So, I did some experimenting and came up with a solution. Then I decided to check the HB forum to see if this had been mentioned before. (Note to self: do that BEFORE experimenting next time!) Well, it turns out to have been well described before, but sort of as an aside to other topics, so I thought it would be worthwhile repeating it now.
The answer is to updose and drop the temperature.
I ended up updosing from 15 g to 18 g, which required a loosening of the grind to achieve a 24 second extraction. The temperature was then dropped from 93 degrees to 91 degrees.
The result is that the espresso went from ashy to sweet and rich. Hooray!
Adrian
