by Benjammer on Tue Dec 13, 2011 4:01 am
I'm a bit late to add to this but I think if the Crema tastes bad, it might be due to your grinder creating too many fine particles that make it into the coffee. I use a Kyrocera hand grinder and noticed (maybe more so if I grind more finely?) that sometimes when making a cappuccino, there's the dark coffee crema/foam that mixes with the cappa foam, when I tasted it, it tasted like fine particles of dirty overextracted coffee. The original poster has a similar grinder to me, which MAY explain why he doesn't like Crema, because it contains the 'light weight' small particles of coffee grounds, which aren't so tasty anymore.
I grind a little coarser and haven't noticed it too much, but yeah I'm going to invest in a high quality (and unfortunately high priced) grinder soon to avoid those fine particles as much as I can.
*update* I went to a highly rated local cafe here, actually TWO and I did notice the crema (well, darker coloured foam in my cappuccino, I pressume its the crema mixed with milk foam) it did have that same super fine (not so good tasting) coffee powder flavour I tasted at home. And they both used the $2000 Robur grinder, so I guess my new vario won't change that! Doh.
