BTW, after wasting half a pound of coffee on adjusting the grind to get to 14g of coffee/28g of liquid ratio in 28 seconds, I finally got it. Still can't drink it straight, but with milk, it's a whole lot better than it used to be. The sour taste is gone, but it's still very bitter.
Interesting side effects of adjusting the grind:
1. I san spin the portafilter to dislodge loose coffee without losing the puck.
2. Can't use my la marzocco double basket anymore because my 58mm tamper touches the walls before being able to apply 30lb of pressure.
3. The vario grinder becomes very sensitive at this grind level and each notch on the left side results in 2-3g of difference in liquid in the output. (I used to move the slide several notches just to get a 3-4 g difference).
4. Have to mix double espresso with 3 ounces of milk to get a decent cappuccino (not too weak). Is 2 fl oz of espresso + 3 fl oz of milk still considered a cappuccino, btw?
5. My eyes are popping with all this increase in caffeine intake (it's probably double or triple the amount I used to get with "lungos"
