mitch236 wrote:Once the brew is stopped there is a pressure release which can cause puck damage.
OP is using a Europiccola, so puck damage
is probably not after the shot is probably not from pressure release. I used a pre-millenium for a few years, and the Europiccolas in general don't like updosing. If I remember right (which I can't believe I'm already having trouble after a few months away from my EPC), my pre-millenium only liked about 12-13g.
Espresscafe, you really need to answer allon's questions for us to be of much help:
How does the espresso taste?
What is your post-shot routine? Could it have fractured after extraction?
How does the extraction progress? Do you need a lot of pressure? How does the grind feel when rubbed between your fingers? What is the coffee? How old is it?
One thing is fore sure, you need freshly roasted artisinal beans. Even something like Wholefood's store roasted beans aren't going to cut it. Get a scale, and make sure you're not dosing too high either.
Living the caffeinated life.
