another_jim wrote:Then dosing becomes a matter of diagnostics, that is, tasting the shot and deciding whether it needs more or less coffee.
Mostly, if the coffee taste flat, without much in distinct flavors, you should dose more. If the coffee tastes harsh and angular, with too many bitter and sours, you should dose less.
I'm wondering if it is presumed that the flow rate stays the same? Depending on how much the dose needs to be changed, might a change in grind be needed to maintain the same desired flow rate?
AndyS wrote:For some time, I too, have believed the same theory: solubles yield is more or less inversely proportional to dose. It stands to reason that low doses, more finely ground, would yield higher. But I'm having a great deal of difficulty proving the theory with actual measurements......
....With the 14g doses, maintaining about the same brew ratio, my measured solubles yield went DOWN 1.5% to 2%. To get back to the 18.5% solubles yield range, I had to pull "longer" shots (brew ratio ~54%, 26g of beverage). [see chart, below]
Some comments on this earlier part of the thread: Aside from prescriptions such as X oz pulled from Y g in Z sec, is there a definition of ristretto, normale, lungo, etc.? I've seen these discussed in various capacities and combinations of dose, % extraction and brew ratio....however, it seems a reference to the product of % extraction and brew ratio (= solubles concentration), as well as this quantity normalized to the dose (i.e. solubles concentration/dose) would be better.
For example, consider the discussion of the high brew ratio shots measured by AndyS earlier in this thread, the 18 g shots are slightly "stronger" than the 14 g shots with higher brew ratios (soluble concentrations approximately = 0.116 vs 0.105 respectively for these shot groups). But, the difference in solubles concentrations is only about 9% despite the 18g shots being pulled from about 25% more dose.
Another way to look at this is that the lower dose shots are actually yielding more solubles per g of dose per g of bev. I think this is the essence of "reason" behind the initial expectation that it "stands to reason that low doses, more finely ground, would yield higher"....they do indeed, per g of dose.
The point I am grappling with is that solubles concentration (i.e. g solubles per g of beverage) sets the scale for the "strength" of the shot (think ristretto, normale, lungo); while the manner in which you get that strength (i.e. from how large a dose - i.e. g solubles per g of beverage per g of dose) better describes the extraction "quality" of the shot. These two quantities seem like they would more clearly define and characterize one shot especially in comparison to another.
