Whale wrote: . . . if you updose a lot and end up with 1 oz or so, you are pretty much pulling a ristretto.
Granted. Thus my use of the word "normale," something that would not result from using an updosed double basket . . .
zin1953 wrote:Granted. Thus my use of the word "normale," something that would not result from using an updosed double basket . . .
qsport wrote:1) that when I use a double filter basket, with 14-16 gms of coffee, with a single spout porta filter, with a 28 second pull for 1oz, then I am "up-dosing"?
qsport wrote:2) and that most espresso cafes use the same set up but use a double spout producing two 1oz shots at the same time, i.e. 8gms per shot ("normal dosing")?
qsport wrote:3) Wouldn't it be a lot cheaper for the shop, and me, to just use a single basket requiring half the dose and not waste the other shot?
qsport wrote:4) Or is it really that much more difficult to produce a good shot with a single basket and/or is there some taste benefit to up-dosing?
qpsport wrote:1) that when I use a double filter basket, with 14-16 gms of coffee, with a single spout porta filter, with a 28 second pull for 1oz, then I am "up-dosing"?
qpsport wrote:2) and that most espresso cafes use the same set up but use a double spout producing two 1oz shots at the same time, i.e. 8gms per shot ("normal dosing")?
