www.baratza.com: skilled in the art of grinding
Convex corrects errors better than flat tampers?
Link to "Convex corrects errors better than flat tampers?"by EspressoGirl on Wed Mar 11, 2009 4:46 pm
I am still deciding between convex or flat and the below quote is from a vendor's website. I am not sure it makes sense to me. Is it really true the convex "corrects" the problem of being off center? I mean, if the whole puck is off center, isn't it just as bad with the curve as with a flat surface?
Convex means that the surface bows out, not in. The idea with convex an how it works it at if ever you are off center with your tamp then the surface will remain the same because the curve left behind will be uniformly the same every time. In extreme instances this is not the case, but for the most part consistency and shot quality will be improved. The other benefit it that with not all the pressure being directed straight down, the curved base allows part of the force to push out towards the edge of the basket helping to seal the sides and prevent water from bypassing the puck and not be infused with espresso before leaving the portafilter.
EspressoGirl
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Wed Mar 11, 2009 5:00 pm
Hog wash :twisted: :evil: :x
I have half a dozen tampers : Flat, C-Flat, European and American Curves. The shape has only minimal effect when updosing on machines that must have clearance between the puck and the shower screen
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by HB on Wed Mar 11, 2009 5:26 pm
The vendor quote is a bit much, but I agree that a convex tamper piston does seem to reduce the likelihood of channeling, assuming an otherwise correct tamp. Maybe. FYI, the poll Flat or convex? shows an overall preference for convex (28% vs. 53%).
On a related note, I've recently been experimenting with "nutating motion" while tamping, something I privately derided as silly. And yet, for some espresso machines, it does seem to reduce the likelihood of channeling. That said, the difference between flat/convex/nutation, if it indeed exists, is quite small.
Link to "Convex corrects errors better than flat tampers?"by Psyd on Wed Mar 11, 2009 5:28 pm
EspressoGirl wrote: I mean, if the whole puck is off center, isn't it just as bad with the curve as with a flat surface?
the idea is that a curve represents the same surface to the puck even if it isn't centered. Tilting a curved tamper a few degrees either way will present (theoretically, at least) the same profile to the surface of the puck, whereas doing the same thing with a flat tamp will have one side a few millimeters lower than the other, showing much less resistance to the water pressure and generating a poor extraction on the high side of the puck, while over-extracting the low side.
Neither tamp will correct a bad distribution, but a curved tamp will not create a bad distribution from a small perpendicularity (word?) error in the same way that a flat tamp will.
<scary midget medium exorcist voice>
This Hog is clean!
</scary midget medium exorcist voice>
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "Convex corrects errors better than flat tampers?"by pavman on Wed Mar 11, 2009 5:54 pm
That's interesting. I have not had extensive experience with both types though I have used both. I tend to go with flat more often, believing that I'll wind up with fewer grinds trapped along the wall around the grouphead and the sides of shower screen that way. This leads to easier cleaning/maintenance, and a feeling the grouphead and screen will stay cleaner, and just be "better off".
I know this doesn't address the issue of lopsided tamping, if we can call it that, but as for this concern, is it valid, or more hogwash?
pavman
Link to "Convex corrects errors better than flat tampers?"by HB on Wed Mar 11, 2009 6:10 pm
I consider it more hairsplitting than hogwash, though the two are not easily distinguished.
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Wed Mar 11, 2009 6:22 pm
"In theory, there is no difference between theory and practice. But, in practice, there is." - Yogi Berra
A tamper with 1mm rocker has a 421mm face radius. The face circumference is 2.645 METERS.
If you tilt a 58mm tamper 3.945° you will raise one side 1mm and lower the other 1mm about the center of the face, for a 2mm differential in your puck. It makes no difference whether the tamper is flat or concave. A BALL tamper with a 58mm diameter could be rotated any which way for a constant, probably crappy, tamp.
Additionally, if the force is directly on the handle axis, and assuming an even initial distribution, the low side will compress / displace the coffee more.
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by pavman on Wed Mar 11, 2009 6:37 pm
ok, but what about whether convex gives the puck "higher" sides, leading to more grounds left on the side of the shower screen?
pavman
Link to "Convex corrects errors better than flat tampers?"by HB on Wed Mar 11, 2009 7:28 pm
Convex or not, if a fraction of a gram of coffee adhering to the sides of the shower screen bothers you, a quick wiggle rinse will eliminate it. I've heard similar reasoning offered for why some baristas tap the portafilter (i.e., less loose grounds = cleaner grouphead), despite that it can lead to channeling. :?
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Wed Mar 11, 2009 8:31 pm
pavman wrote:ok, but what about whether convex gives the puck "higher" sides, leading to more grounds left on the side of the shower screen?
If you updose, the puck is more solid and leaves less mess on the screen. If you 'normal' dose, the puck explodes into a goopy mess.
Personally, I dose for taste and don't give a rat's patoot about sanitation. :roll:
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by RapidCoffee on Wed Mar 11, 2009 9:06 pm
The second half of the quote (taken from the EP website; let's give credit where due) makes more sense to me than the "off center" hypothesis:
Convex pistons appear to be slightly more forgiving; a perplexing observation, since a level, even puck surface should result in an optimal pour. But water under pressure will seek the path of least resistance to flow. When the puck has been tapped or overdosed, this path may be the side seal between the puck and basket. A convex piston forces coffee away from the center towards the sides, helping to correct such flaws.
Again, this is a subtle effect. I prefer to concentrate on grind, dose and distribution. Get those right and any tamp should work.
John
RapidCoffee
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Thu Mar 12, 2009 12:40 am
Sorry, but all force is directed straight down. Assuming a level distribution, the center of a convex tamper will contact the coffee first. Coffee is not 'slippery.' As the piston continues into the coffee, the center compresses more than the sides. Whether and how much the coffee displaces from the center or just compresses more needs investigation.
It's possible to measure the difference in force applied to the side of the basket with a convex tamper vs a flat one. It's my guess that it's in the realm of inconsequential.
Seems like a project for Ken and Jim.
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by RapidCoffee on Thu Mar 12, 2009 2:27 am
cafeIKE wrote:Sorry, but all force is directed straight down. Assuming a level distribution, the center of a convex tamper will contact the coffee first. Coffee is not 'slippery.' As the piston continues into the coffee, the center compresses more than the sides. Whether and how much the coffee displaces from the center or just compresses more needs investigation.
If so (greater compression in the center), I am truly perplexed. This would imply that the chances of a donut extraction are enhanced with a convex temper, which runs counter to my experience. Ditto for the infamous nutating tamp, which by all rights should create a small mound of coffee in the center of the puck prior to compaction.
I think coffee may indeed be somewhat slippery. :?
John
RapidCoffee
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Thu Mar 12, 2009 2:45 am
Methinks we don't know our arse from a hole in the ground when it comes to what happens in the basket. :?
In nearly 3 e61 years and flat vs several convex tampers, other than the aforementioned clearance on updoses*, no advantage accrues. Ditto ultra close tolerance.
* IMO, the e61 is next to impervious to shower screen contact.
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by cannonfodder on Thu Mar 12, 2009 10:15 am
E61 may be easy going but I have a couple different machines that are very picky about dose, and one in particular that is very picky about tamp. That machine had a noticeable improvement based on the tamper shape used, and it was an original Faema with a solenoid actuated group. So on a rare occasion, yes the tamper shape will make a difference, but I believe that 99.5% of the time, it is all window dressing. Personally, I tend to use a flat and convex interchangeably although I usually stay with a tamper that matches the shower screen. Convex screen, convex tamper, flat screen flat tamper but I see no marked difference between the two on my current kit. No amount of tamping or a 0.001mm basket to piston tolerance will do any good if your grind/dose/distribution is off.
The only purpose tamping has is to ensure an evenly dense puck of coffee so the water flows through it evenly. So start with an even distribution and you could tamp with anything that is level and reasonably sized to the basket.
cannonfodder
Link to "Convex corrects errors better than flat tampers?"by sweaner on Thu Mar 12, 2009 10:55 am
Sarah, do you now see that you are over thinking this? The tamper is probably the least important aspect of espresso making. However, I think they look great. Find one that looks good and fits the basket and you will be good to go. I really want a Pullman tamper because they look great. I have no thoughts that one will improve my shots.
*Oh, you want to know what has improved my shots the most? Dave Stephens when he came over to work with the MVP Blend! I suggest buying a Dave Stephens or someone similar. I think EPNW carries them. :lol:
Scott
LMWDP #248
Man does not live by coffee alone. Have a danish.
sweaner
Link to "Convex corrects errors better than flat tampers?"by cafeIKE on Thu Mar 12, 2009 11:41 am
cannonfodder wrote:The only purpose tamping has is to ensure an evenly dense puck of coffee so the water flows through it evenly. So start with an even distribution and you could tamp with anything that is level and reasonably sized to the basket.
Or nothing at all :wink:
cafeIKE
Link to "Convex corrects errors better than flat tampers?"by EricL on Thu Mar 12, 2009 11:49 am
Poor Sarah, she just wanted advice on buying a tamper, and gets sucked into a life and death struggle between the forces of flat and convex, all over the existence or not or fluid like particle flow at the micro level and the dynamics of irregular shaped particles under pressure. Where's a micro-geologist when you need one.
EricL
Link to "Convex corrects errors better than flat tampers?"by bgn on Thu Mar 12, 2009 12:02 pm
I read the same tamping quote about convex/flat while trying to decide what to buy. I don't have the privilege right now of buying several tampers, but in the future I hope to buy more and want to own a flat, but for my first I bought the convex. Not that I expect any magic, but I had to choose! I bought the espresso lab design one from Australia for a good price that included shipping to Canada. Can't wait to try it!
bgn
Link to "Convex corrects errors better than flat tampers?"by EspressoGirl on Thu Mar 12, 2009 2:01 pm
Oy! What a "hobby" this is! It seems hard to see the end of the tunnel where I will finally have all the equipment I need for a great shot and great microfoamed milk....
Someone mentioned which vendor the quote came from. I purposely had left that information off in case there was dissent and I didn't want that to negatively reflect on my vendor....
EspressoGirl
Next
Return to Tips and Techniques
