by Psyd on Thu Mar 12, 2009 4:28 pm
Just remember that everyone has different experiences, 'cause everyone lives in a different clime, altitude, with different water, different grinders, and different machines with different accessories. The combination of variables that would allow your experiences to directly parallel anyone's here would require identical kit, in your kitchen, and would make the whole forum thing moot.
Anyhoo, regardless of anyone's stance that this is or this is not the way, keep that in mind when you ask such questions. Take the Root Mean Square of any response, discarding both the highest and lowest three scores as fanatics who aren't to be persuaded by facts.
And if this vendor has published his pet theories online somewhere, he knows that one of us will eventually see it and challenge it. We're a very skeptical group, and they've either decided that they have evidence to back it up, or hope for sales til they're exposed! ; >
Truly, they vend the stuff, mostly, from the designer and inventor's promotional hype. In effect, they are usually telling you what they've been told to sell the item. The theory that I repeated seems to have been well shot down by cafeIKE, as well as the one that it may help seal the edges. Since he will regularly advocate a no-tamp, he may have his own agenda, or the e-61 will work equally well with anything from no tamp at all to the bottom of a jelly jar. cannonfodder, OTOH, has regular exposure to many different machines, and many different tamps. He says that it will make a difference, and it may be one or the other of the theories being debunked that is the reason why. Or not.
When you arrive here, what you're looking for is a number of responses to give you an idea of a direction. Those in the situation most similar to yours should carry the most weight. While there are quite a few very knowledgeable folks that post here, there are a large percentage that won't have any experience with a lever machine, or haven't ever touched a Gaggia Classic. Not having touched the machinery that you're playing with, their advice might be great, just not applicable. Take it with as many grains of salt as you think you might need.
As far as tampers go, unless you're pulling with the frequency of a pro, the most important factor is what it looks like when your friends see you using it. I had a fifty-three mm jelly jar for quite a while.
make sure it fits, and get a flat or a convex. Then, later on, get the opposite base for it and compare. Then, even further down the road, get another handle so you have both! Once you've figured out which one actually makes the best coffee, sell the other on ebay, CL, or CG, so another HB gets to make the experiment!
Espresso Sniper
One Shot, One Kill
LMWDP #175
