That's interesting that you prefer to keep the wand vertical. I'm using the same four-hole wand on my Anita, and I get the best results by pointing the wand out from the machine at an angle and placing the tip near the right hand side of the pitcher with the pitcher tilted slightly towards me. Surf the tip just under the surface until it expands a bit and starts feeling warm to the touch, then lower the tip a tiny bit and let it swirl until the pitcher is too hot to touch. Voila, great microfoam pretty much every time.
Still, if pointing the wand straight down works for you, that's all that matters. I don't think there's any one right answer. Just find something that works for you and stick with it.
