Coffee-Red Bird Espresso, Northern Italian Roast and roasted on 7/19. Great company to work with by the way. Roast is also probably a bit fresh but I was anxious.
7/22/11
First time operating espresso machine aside from some horrible attempts to create microfoam with the steamarm. Bought Pasquini Livia 90s used and backflushed(using cafez and pallo cleaning tools) machine. Steam wand and portafilter sat overnight on 7/21/11 in citric acid bath.Shot yr old beans through machine to pick up any residual cleaning agent. I may descale after my first pound of beans.
Machine sat heating ~1.5hrs. Pasquini Livia 90s
I did not concentrate on hx flushing because I wanted to focus more on loading the portafilter correctly and tamping, one thing at a time. Warmed shot glasses and portafilter and then loaded 22.0 grams on Vario hopper. Ground with macro setting at finest notch and micro setting nine notches from coarsest setting. Brushed excess off with finger and lightly placed tamp on portafilter and proceeded to twist slightly. Lifted tamp and it was clearly not level. I then gave the tamp a good bit of pressure realizing that it was not level but struck it up to me just needing practice. I then loaded portafilter and then unloaded to see if I could see the screw mark in the coffee portafilter basket. Due to the uneven tamp their was a bit of clumping of coffee clumped to the grouphead screen and a big ole pocket in the portafilter but alas I locked and loaded(remember this is my first shot ever). 10 seconds go by and no espresso so I stopped the run and decided to try less coffee.
17.7g
I used the same grind(probably needed to go more coarse but only wanted to change one variable) with slightly more level tamp but still visibly uneven. Tried again to place portafilter in and then out to see screw mark. Same result with clumped coffee on group head but a fair amount less. I still attribute this to a piss poor tamping job. Pulled shot and espresso started to flow around 4 seconds and also blonded for a bit at the end. I stopped the shot at 26.9 seconds. Sink shot.
Between each shot I am doing a portafilter wiggle and cleaning the clumped coffee with pallo tool(necessary with my ugly barista skills).
3rd and final try for today and hopefully with a video if I can embed it properly. Looks like I will try to edit in the video
17.6g used and I adjusted the grind one notch coarser on the micro setting side.
I tamped lightly and got a pretty even surface from the naked eye view. I then used a much slower tamping speed but ~ same pressure which hopefully helped with any air pockets. I did not remove the portafilter this time to check for screw mark. This shot ran for ~45 seconds but may be slightly off as I was running video.
The first two pucks where pretty much garbage to look at but the third puck was at least worth diagnosis. A few pinholes and probably channeling as well.
I am a bit unsure what size basket came with my machine but I am assuming it is a double. I may end up getting a naked portafilter and will probably get some VST baskets simply because they have some good recommended gram dose ranges that would be one less variable while I am learning.
3rd shot video and images.
you can see the holes etc.
Pressure must be high as you can see it bleeding out water in the background.Going to go more course next time.
