boar_d_laze wrote:Try to get your grind settings right. In addition to bean type and age, the best grind setting will also change with the weather. Be flexible with your first couple of shots, and willing to change the grinder. What you did yesterday may bear little resemblance to what you should be doing today.
Ive come to realize a difference in the SO CC apollo vs the redbird blendYou don't need to dose by weight. Slightly overdose the basket and use a finger sweep to level and get rid of the excess grounds. Whatever that is, it's the right dose in the stock basket. If you like, you can weigh the charge to see how consistent it is -- you'll be pleasantly surprised.
18g has been a slight overdose in the double basket. It is a bit hard for me to get away from the analytics of it all but I may need to sit back and erm watch the flow The Livia is not very demanding about tamps. Grind a little finer and use a lighter tamp than you might in another machine -- if that means anything to you. If it doesn't, just try and get your grind right and don't worry about it for a few months.
I get the jest of what you are saying here and will give it a go! My vario still has one tab finer on the MACRO side so I am sure I am a bit coarse. Problem is if I go to finest macro setting even with a coarse micro setting than I clog the groupheadYes, a level tamp will make a positive difference in the cup. After dosing your basket, very lightly tamp it just to level. Take a look to make sure, then give it your best "real" tamp. BTW, it can be significantly less than the supposedly ideal 30#.
There's nothing wrong with the stock baskets. You don't need an LM or Synesso to get great shots from the Livia. You might want to pull shorter shots though with the shallower baskets. Whatever you're using, don't overfill.
Dont overfill? didn't you just recommend a slight overfill,brush off with finger and tamp? would it help if I dosed what I do in the double into a triple for headspace?Okay, tamping isn't next to Godliness, BUT... For heaven's sake, get a tamper that's the right size for whatever basket you're using. That means one which will go all the way down to the coffee. What are you thinking with a tamper too big for your basket?
well I have a 58mm tamper and it fit my triple and single fine. Being new to espresso I mistakenly ordered a pasquini double(figuring I would want to make sure it fit as it said for pasquini) but the basket is tapered so it is 58mm on top but tapers to say 53mm
very disheartening and probably unusable. It does appear this has happened to a few individuals on CG in which they recommended a lighter tamp and finer grind, different basket or smaller tamper. I wanted a double to learn on because I was going through 21-22g on the triple pretty fast
I bought my Livia in '88 along with a Pasquini Moka grinder, and used both of them daily for 22 years. For almost all that time, I "up-tamped" Euro-style on the tamper screwed to the Moka's doser. It was a lighter tamp and a finer grind than most baristas would use with a regular tamper, and it worked just fine. In case you missed it, the moral of the story isn't "up-tamping," it's how un-demanding the machine is in that respect and how much you can do with grind.
You want enough coffee in the basket for the size shot you've decided to draw. You want enough of a tamp to maintain headspace, keeping the top of the puck under the screen and out out of the works. You want a fine enough grind to prevent under-extraction and coarse enough to prevent over-extraction. Everything else is nuance. It
is nice to use tamp pressure to help control flow rate -- but stay conservative and don't tamp too hard. Grind is your best source of control, your primary parameter.
tamp effects flow? hmm more variables
by the way your review of the livia has been a wonderful source of informationIf it's any comfort, you haven't stood still. Over the course of your ownership, your grind and distribution techniques have improved to the point where you're not starting with a complete clog or a gusher. That's very good.
Well, the fact that my wife ditched her brand new brewbot for my cappas has helped granted piss poor milk technique to boot as well.At this point, the most important piece of advice I can give you is not to be afraid of the off switch. Turn the pump off when you get blonding, not by volume or because you're hoping to get close to a particular pour time. You're waiting too long.
Blonding is a clue. If the coffee blonds too fast, you want to make sure you're getting enough coffee into the basket, getting it in there evenly, and that it's ground fine enough. But more often than not, it's a sign that the fines are fully extracted. You can think of it as "not enough coffee," which is sometimes true; or as "too much water" which is always true. I'm not going to say that your shots are blonding too fast (they're not), but I am seeing too much blond before you turn off.
I appreciate this! I have been afraid of the off switch and will start using itA lot of other things are clues too. So watch the coffee more than the clock, the dynometric tamper, the dosometric buttons, the gauge, the scale, or anything else you're counting on for "objective" or quantifiable certainty. The goal is coffee, not a set of numbers. Look, listen, smell, touch, taste.
Here's an example: Where in the cooling shot do you stop hearing steam sputters? What's too soon? What's too late? If you hear sputtering at the end of the shot, do you pull another blank? If the sputtering stops after the first couple of ml, do you wait a while before pulling the real shot to give the machine a chance to recover?
Hmm, I may just need to post a video of my whole routine but my cooling shot is only a few ounces. I am not sure I even hear sputters and may have adjusted the dial next to boiler to far but will post a video. I only pull one blank typically 2 ounces and immediatly pull shot. I was told livia has a very quick recovery and needed a small cooling shot to start.The biggest challenge with the Livia is temperature control. Your shot pull videos are very informative, but it would be interesting to see your pre-shot routine as well -- including dosing, tamping, and whatever "cooling shot" routine you use.
Use the tastes of bitterness and sourness as your primary diagnostic tools for "too hot" or "too cold." Pay attention to what you taste.
I know the drip tray is small and inconvenient, but be profligate with water. Lots of water is an HX's best friend.
Everything inside the Livia's group gets dirty very easily, and needs frequent and thorough cleaning. More than just backflusing, that includes regular removal of the screen and showerhead. Plan on: (1) DAILY brushing and backflushing the group, scouring the pf and basket, emptying and rinsing knock box and drip tray; (2) WEEKLY backflushing with a chemical cleaner such as Joe Glo or Full Circle, including soaking the basket and pf in a "wicked liquid" solution of cleaner and water for at least a few hours before scouring, wash the knock box and drip tray with soap and water or in the dishwasher; and (3) MONTHLY removal and soaking of the screen and showerhead. The Livia showerhead clogs easily, and is very difficult to clean if it does.
Also, keep the area around the Livia (including the knock box and drip tray) very clean. Old, smelly coffee will mask the new coffee's smells. Check under the machine every day by tipping it backwards, after you remove the drip tray. Wipe and/or clean as necessary. Wipe down your machine when you replace the drip tray after rinsing, it will help you spot problems before they occur.
The best and easiest way to keep things clean is to clean often.
Right now I am doing a portafilter wiggle after each shot. cleaning with pallo brush daily and backwashing with cafeza weekly but I havent yet removed the showerhead,dispersion screen, grouphead. I do wash portafilter and steamwand in solution. It was bought used but from a supposed espresso tech.Hope this helps,
BDL
