Ian_G wrote:I have no idea whether what I am tasting is what I am meant to be tasting.
Brilliantly put. That is one of the big dilemmas of doing coffee on-line.
One method is to find a good local cafe that sells whole bean bags of the coffee they serve. Have their espresso and brews, buy some beans to take home, and compare your prep to theirs. There will alway be differences; but you'll be able to tell if you're playing in the same league.
If you find that your home coffee is a lot better than the cafe's even after trying them several times, then the experiment is a failure, since the cafe you were using was probably not very good.
You'll beat even a good cafe on occasion, since everyone has bad days, but not consistently. So a good cafe is one good resource for testing yourself.
The other good possibility is to find another Glaswegian amateur with whom you can compare notes.
Finally, combining the two in a local get together among amateurs and pros is the best way to assess yourself.
