another_jim wrote:Ian, with an E61 box, advised doing a backflush with waste ground coffee before beginning a session.
You mean with a blind filter? Like a real backflush cleaning operation? Driving coffee/oils/grounds back into the group?
Interesting. Remarkable. Looking for words.
So the backflush 3-way implementation actually is a design error?
You would want a dedicated tube into the headroom between coffee bed and shower screen through which to release the pressure at the end of the shot.
Or, as I pointed to before, on an E/61 machine, switch off the pump just before the end of the pull, with the E/61 lever in the middle position - now pressure in the headroom presses coffee out whilst pressure ramps down and there is (almost) no flush through the pressure exit. I have seen Italian barista do this almost always on E/61 brew head type machines and some of them say they can taste the difference.
When I dose low and hence grind very fine, and at the end of the shot push the E/61 lever back all the way as fast as possible, I run a big chance the coffee puck is hanging on the shower screen when I take the portafilter off. The procedure above would give me a clean shower screen (towel and/or Pällo brush).
Regards
Peter
