www.baratza.com: skilled in the art of grinding
Choking - is it bad ?
Postby pedepy on Mon Dec 21, 2009 9:07 pm
the espresso machine kind, of course ! ..
i keep 'choking' my gaggia because, well, i find it makes the most kickass coffee i have ever drank. it's like syrup, warm and barely any bitter.
however i'm always a little concerned when i see my 300$ beast choke the way it does; i always worry when i see no coffee come out after 5 seconds or when i look at that coffee, dripping one drop at a time, giving me barely half a small cup after 60 seconds. but boy is it good ;)
so .. is this stuff bad for my machine ?
pedepy
Postby HB on Mon Dec 21, 2009 9:14 pm
You describe a very tight ristretto. The machine should be designed to withstand the maximum pressure the vibratory pump can produce (usually 16 bar), so there's no reason to worry that it will damage your espresso machine. Technically the pump can overheat if it's run for more than 1 minute without a 1 minute rest, but that's a minor concern.
Return to Tips and Techniques
