jrtatl wrote:Some like a finer grind, some coarser. Experimentation is the key.
Siglo:
I agree. When I jump back and forth between baskets (ridged, ridgeless) particularly when I move from double baskets to triple baskets, I need to modify my "routine" a little to produce the best result in the cup. A couple of things that might help you: try 17, 18 or 19 grams in the basket instead of your stated 20 grams. My Andreja starts to "complain" if I overdose the basket significantly (FWIW, so does my A3). Another thing that helped me was to utilize the "grind finer, tamp lighter" approach.
Play with it- experimentation in order to figure out what works the best for you personally is half the fun!
