by cannonfodder on Tue Feb 23, 2010 12:41 am
Half a gram variance in dose will make a noticeable difference. In the grind/dose/distribution/tamp sequence, the tamp is the least important of the bunch. if you tamp with 30 pounds or 50, consistency counts. While no amount of tamping will repair a poor distribution, a bad tamp will destroy an otherwise good distribution.
I did away with the portafilter tap a year or two ago. I do thump the portafilter on the tamping stand 3 times, lightly and straight down, after i knock the top of the dose cone down but I try to avoid that by dosing around the basket and not all in the centre. That settles the coffee down then I give it one light tamp and go. Most of my doses are well below the rim of the basket for headspace on my particular machine.
As long as the coffee is fresh, you should be able to get a good triple. Open up the grind a little in comparison to a double, make sure you are dosing the same amount every time, keep the tamp simple and light.
