Thanks guys,
To be honest, that is pretty much what I assumed. I figured that the Calcite filter would be used for an RO system purely to get the machine to sense water in the boiler, IE: not add enough to make a worthwhile difference, taste wise.
Nicholas, Once I move in and get my machines set up, I planned on trying the AB packets to see what, if any difference I could notice. And if it IS a noticeable difference, and worth using them, then I probably will. Im not 100% against using a Flo-Jet... That was my original plan.. But when I decided to put my Espresso Bar in a different spot of the house, and realized I could do a direct plumb and drain, which excited me. So, we'll see what happens.
Where I live Currently, the water coming is is good, just hard.. But no bacteria, Iron, Chlorine etc etc. So Ive got a whole-house softener, which, again, puts the water at about 3 grains. And since Ive got a pour-over machine, ive been able to mix tap/treated water to get the water between 7-8grains, alkalinity about 100.. So I guess Ive spoiled myself. But maybe Ill get lucky and won't notice enough of a difference to care. That'd be nice. I am going to put a micron sediment filter for piece of mind. And yes, regulator after the filter(s). . . Question; can a pressure regulator raise pressure, if needed?(just curious)
Thanks guys, I appreciate the help
Oh, and by the by, Dave, how is your house coming? If you're anything like me, I bet your just itching to move in
