by RapidCoffee on Sun Aug 21, 2011 1:43 pm
Yes: the difference between volume and weight (or mass).
Depending on the amount of crema, 45ml might weigh 22,5g (yielding a 67% brew ratio) or 30g (yielding a 50% brew ratio) or even 45ml (no crema whatsoever, yielding a 33% brew ratio). This spans the range from lungo (33%) through normale (50%) and even ristretto (according to AndyS, 67% falls in the ristretto range). You need to weigh the extracted beverage as a reality check; volume simply won't do the job.
John
