Can't pour two cappuccinos
Postby faberic on Wed Jun 06, 2007 1:44 pm
Hello,
Now I've mastered several techniques for espresso and cappuccino, i'd like to show them off to my friends. But: When I try to pour two cappuccino with just one pitcher, the first one's got lot of foam, and the second one lots of very wet, latte-like foam. The foam is pretty nice since I can pour some latte-art with it.
Is there any trick or something I should know, or is the foam still bad (even if it looks like microfoam).
Faberic
faberic
Postby Niko on Wed Jun 06, 2007 2:13 pm
What's the size of the pitcher in use?
I'd start to pour them together, share the pour by alternating the milk between the 2 cups back and forth and then when you're about to start hitting into the microfoam, split that off and share between the 2 cups. That's how it works for me with the smaller 16-20oz pitchers, you can got to a larger pitcher and make it easier for yourself just by doing it one at a time when more steamed/foamed milk is abundant.
Niko
Postby HB on Wed Jun 06, 2007 2:28 pm
Pros frequently used two pitchers during competition as reported in USBC 2007. Some related suggestions in Latte Art Challenge(d):
HB wrote:PeterG once suggested letting the milk sit a short spell and then doing the thunk / swirl thing to reincorporate them. In competition, baristas will frequently swirl the pitcher in a small circular motion on the countertop. It keeps the motion repeatable and controlled, especially when you're nervous. I've never tried transferring between pitchers like competitors routinely did last year, but I think the same technique could be applied. Abe commented on this in USBC Barista Competition - Competitor Debriefing:
Abe Carmeli wrote:Tricks I learned from the pros
If I learn only one thing from an espresso jam I consider myself lucky. During the judges certification workshop, we were served drinks by two USBC Champions, Bronwen Serna & Phuong Tran. Both terrific baristas.
Avoiding Crema Bubbles
Bronwen is famous for her cappuccinos, and here's what makes her shine: Often, a cappa will show crema bubbles. This may not affect the taste so much as it affects the visual. To avoid crema bubbles she drops a little foam to the cup and immediately starts swirling and banging it on the counter as one would do with a steaming pitcher. After she is happy with the result she pours the rest of the milk.
A perfect cappuccino by Bronwen Serna served during the judges certification workshop.
Pouring Even Cappas
This one comes from Intelligentsia. Ellie, Amber & Matt all used it. The problem with using one pitcher to pour two cappuccinos is that the first pour will have more foam than the second. To avoid it, pour some of the foam into a 2nd pitcher before you pour your first cappa. Then use that foam to top off your 2nd pour.
Return to Tips and Techniques
