Can I leave my portafilter engaged overnight?? - Page 2
Postby Marshall on Fri Sep 16, 2011 12:06 pm
mitch236 wrote:I hate replacing that gasket!!! I've tried all sorts of special tools and still struggle to get the old one out!! It always cracks into pieces and I have to fight for each piece! Maybe I try to get too much use out of each gasket?? :lol:
If it cracks into pieces, you've waited too long to replace it.
Marshall
Los Angeles
Marshall
Postby spiffdude on Fri Sep 16, 2011 3:48 pm
Ahem, gasket issues are a PITA, both on espresso machines and old men...
As far as E61 groups go, changing a gasket once a year is super easy. All it takes is a spoon or some other flat piece of metal and 5 minutes. That's why i do not worry about this and leave the portafilter in there. On the Rockets, the shower screen has a notch on the side, so it makes it even easier. A no brainer for the OP as far i am concerned!
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
spiffdude
Postby spiffdude on Fri Sep 16, 2011 3:49 pm
Marshall wrote:If it cracks into pieces, you've waited too long to replace it.
+1
spiffdude
Postby shadowfax on Fri Sep 16, 2011 5:01 pm
cannonfodder wrote:I always leave the portafilter in the group. Just don't crank it in super tight.
+1 to this. Cranking the gasket when idle seems to accelerate the deformation of my gaskets.
I leave the basket out of my portafilter when not in use (usually on the cup tray, but not always). This lets the portafilter lock in loosely at 90°. That way if it gets bumped slightly, it's less likely to fall out of the group.
Nicholas Lundgaard
shadowfax
Previous
Return to Tips and Techniques
