cherbhy wrote:Plusx,
Not to "piggy-back" on this thread, but I'm curious... Does the shower screen on your group head distribute water unevenly? Is this normal? Does your machine run the same way?
Craig
No please "piggy-back", I would love to see a dedicated Aroma/Classico thread. My shower screen distribution isn't exactly even, but no it does not 'squirt' out the center under pressure like in the video you posted. That I imagine would immediately chew a hole through the puck. I have no advice except maybe remove the screen and see if it is something obvious causing pressure in one spot.
TrlstanC wrote:I've been experimenting with pre-heating the reservoir water (see here:
Any harm from pre-heating reservoir water?) which has been a lot more consistent for me then trying to temp surf. And I haven't seen any detrimental effects on the machine (yet).
Interesting! My water temperature does stay even throughout a thirty second shot so it isn't an issue for me but I also turn on the pump and let steam/water run out until the steam light goes out (approx 3 secs). Then I immediately stick the PF on and pull the shot BEFORE the steam light comes back on. This keeps the element on throughout the shot.
asdf777 wrote:Measuring steam temp in the cup, it was about 204-7F, so there is about 5-8F loss going between the dispersion screen and cup's bottom. All in all, in my case, it's about 20 degree drop between boiler and coffee grounds when machine is warmed up.
Thanks asdf777, that helps confirm temperature drop numbers.
